Big 3 Upgrade: I've searched, but...
Old Dec 18, 2013 | 06:46 PM
KerbyG's Avatar
KerbyG is on a distinguished road
Ohh okay!
Old Dec 23, 2013 | 01:24 PM
jpimp's Avatar
jpimp is on a distinguished road
What did you choose for side post terminals?
Old Dec 23, 2013 | 03:04 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Use a old extension cord or some rope, lay it out under hood and draw lines with a sharpie and cut your wire to length. I bought extended terminals for my 04 CC when I had it, my blazer has a dual post battery and I went cheap and just bought new terminals for the top. I don't remember what sizes I used for eyelets as I drilled mine to fit after I torch soldered them to the wire.
Old Dec 24, 2013 | 11:00 AM
Diaita's Avatar
I just got a couple of these in a 2/0(i put two 1/0 wires in it) wire size, with a 3/8 hole. I don't use the red/black terminal covers anyway.
Attached Thumbnails Big 3 Upgrade:  I've searched, but...-28rl53_as01.jpg
Old Dec 24, 2013 | 11:38 AM
newguy's Avatar
isnt 1/0 bigger that 2/0? Typo maybe? Anyway thats what I used and I used a large flat head screw driver and a hammer to crimp it on the wire
Old Dec 24, 2013 | 02:17 PM
Jamaroon's Avatar
no, 4 ga < 2 ga < 1/0 < 2/0 < 3/0 etc.
Diata, are you planning on protecting the welding wire some way? I've read about welding wire not holding up too well in an engine bay.
Old Dec 24, 2013 | 03:36 PM
swells87's Avatar
swells87 is on a distinguished road
When I use those terminals I will normally drill a small hole in the top and solder the wire in, a small butane torch will normally get it hot enough than feed the solder in through the hole, a trick my dad taught me from when he was in the navy. I don't trust crimping for some reason, I prefer to solder if at all possible.
Attached Thumbnails Big 3 Upgrade:  I've searched, but...-28rl53_as01_zps318e074b.jpg
Old Dec 25, 2013 | 11:57 AM
Diaita's Avatar
I hadn't planned on protecting it, I've run it on other trucks for years with no issues. I have silicone/fiberglass insulating sock I put over it if its near a hot spot. I know some cheap cables are only covered in vinyl, which wouldn't last at all.
Good call on drilling the hole Swells. I am just going to crimp them and shrink wrap them since we have all the equipment at work.
MERRY CHRISTMAS!!!!
Old Dec 26, 2013 | 10:41 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
great idea planning on doing the BIG 3 this weekend
Old Dec 27, 2013 | 03:29 AM
Blade_24k's Avatar
Blade_24k is on a distinguished road
I hate to thread jack, but I have a question. When doing the big 3,is it replacing the stock wiring completely, or are we just leaving the stock wireinf there and adding the 1/0 awg to it?
