Blinker doesn't work on back right side of car?
Old Aug 18, 2013 | 09:21 PM
djc04's Avatar
djc04 is on a distinguished road
Default Blinker doesn't work on back right side of car?
I have a 99 chevrolet blazer 4wd. It's got about 130miles on it. When I use my right side blinker it makes a really rapid blinking sound and only in the front side the light blinks, the rear does not flash on the right side. The left side blinker is fine for both front and back. Any clues on to what this could be and how much it's going to cost me?
-Dom
Old Aug 18, 2013 | 09:25 PM
Thogert's Avatar
Burned out lights probably. If so, $10 at most for new bulbs.
If not it could be a bad ground or light socket or wire problem somewhere.
Old Aug 19, 2013 | 12:29 PM
djc04's Avatar
Okay. I didn't think it was the bulb because the brake lights work and it seems that they use the same light bulb? I did have a Uhaul place mess with the electrical back there to install a wire harness in order for lights to work on the trailer that was hooked up to my vehicle. Now that I think about it I do recall that the right blinker did not work on the trailer but the left did so maybe they messed something up.
Old Aug 19, 2013 | 12:40 PM
BlazerRazor's Avatar
BlazerRazor is on a distinguished road
It's either the light in the blinker or a taillight bulb out, check them all. It's super simple to fix and usually very obvious which bulb (and some times bulbS) need to be replaced.
Old Aug 19, 2013 | 04:13 PM
Thogert's Avatar
Ok, yeah if the brake light works on that side then it's a wiring issue.
Old Aug 19, 2013 | 05:20 PM
xgiovannix12's Avatar
did you check the blinker fluid? Lol JK
if both brake lights work then there is an electrical issue somewhere. Id start by the trailer plug if you have one.
Old Aug 19, 2013 | 05:37 PM
Thogert's Avatar
Gio we've been over this 1000x, blinker fluid doesn't go bad.
Old Aug 19, 2013 | 05:46 PM
it does leak tho
Old Aug 19, 2013 | 06:13 PM
djc04's Avatar
Fixed! It was the bulb. Thanks guys for your input.
Old Aug 19, 2013 | 06:53 PM
Glad its all fixed
Make sure you check your blinker fluid... This is why bulbs burn due to the blinker fluid not cooling the bulb off.
lazer2000
Sep 16, 2012 11:16 PM
blazintexas
May 1, 2012 06:01 AM
GolfClapperX
Aug 18, 2011 12:25 AM
ChevyFamily
Jan 27, 2011 01:13 PM
redpeppers
Apr 7, 2007 04:55 AM
