Broken hazard button and now no break lights or turn signals
Old Feb 8, 2025 | 08:27 PM
Missmead's Avatar
Missmead is on a distinguished road
Default Broken hazard button and now no break lights or turn signals
What do i do
Old Feb 10, 2025 | 02:17 PM
El_Beautor's Avatar
If the hazard button is not reparable, then you'll likely need to replace the whole multi-function switch assembly. You can order them from most parts websites, or you could probably get a used one from a u-Pull type place. It's possible to do the job with common hand tools, and the procedure depends on what year and model vehicle you have.
Broadly you'll need to:
  1. Remove the lower dash panel to access the connector plug for the multi-function switch. I believe it's connected with an 8mm retaining bolt.
  2. Remove the steering column cover. There will be 2-3 torx bolts (I think T25?) holding it together, then several clips to separate it. You'll also need to unclip the key cover over the ignition assembly to remove the steering column cover.
  3. Unbolt the multi-function switch. If I remember correctly it has 2 6mm bolts attaching it.
You can identify the connector plug you need to detach by following the wires from the switch on the steering column. There will be 2 separate flat plugs, attached together one on each side of a harness. If you look up the switch on a parts supply website you'll see what they look like. I believe one plug is blue, and the other is white.
Hope this helps.
Old Feb 10, 2025 | 07:21 PM
Missmead's Avatar
Hope this helps.
Thank you so much. It's a 98 gmc jimmy blazer btw. I'll keep you updated.
Runhag
Mar 29, 2019 01:59 PM
vfeichten
14
Dec 18, 2017 01:55 PM
BeufordRULES
Mar 9, 2012 02:36 PM
chilecol
Sep 2, 2011 05:59 PM
dmoore96
Feb 28, 2011 06:27 PM
