Blazer 1988 No turn signal.
Old Mar 28, 2019 | 12:45 PM
Runhag's Avatar
Runhag is on a distinguished road
Default Blazer 1988 No turn signal.
Hello. I have no turn signals. Fuse is ok and i have replaced flasher on the fuse block. Read somewhere that there could be a second flasher om top of steering column but have not seen one. Checked the front direction lights and they have ground in bottom of the sockets. Any tip would be much appreciated.
*Solved. This button deactivated turn signals.. ?
Old Mar 28, 2019 | 06:04 PM
cleburne red's Avatar
Why on earth is there a button to deactivate the turn signals? What's the benefit of that?
Old Mar 28, 2019 | 08:28 PM
odat's Avatar
I think that is what is left of the emergency flasher/ 4 way button - it will lock out the blinkers and if the flasher that controls them is bad nothing will flash
Old Mar 28, 2019 | 09:19 PM
That makes sense
Old Mar 29, 2019 | 03:06 AM
Runhag's Avatar
Yes makes sense. Where is that flasher located?
Old Mar 29, 2019 | 01:59 PM
odat's Avatar
Search shows right hand side of the steering column under the dash and close to instrument panel on a pig tail in the wiring harness so I guess I'd start with looking there.
darkstar145
Nov 23, 2017 07:14 PM
xXPurpleDogXx
Apr 2, 2016 01:12 PM
BigEffingHammer
Jul 18, 2012 10:32 PM
dmoore96
Feb 28, 2011 06:27 PM
94 S10 Blazer
Mar 23, 2009 04:56 PM
