Can someone answer some question about power to the overhead console
Old Nov 24, 2012 | 07:34 PM
stinz's Avatar
stinz is on a distinguished road
Default Can someone answer some question about power to the overhead console
I want to get a cam and have it powered on when the key is in the ignition. My line of thought is to install the camera on the rear view mirror and run the cord up and tap into the power supplying the overhead console that gives temp and direction.
Is the console fed by a 12v power cord? Does this sounds like a horribly bad idea?
Old Nov 24, 2012 | 08:21 PM
warthogdriver's Avatar
Sounds fine to me. Yes the overhead is 12v. I did a write up on modifying the display up there.
it will tell ya what is what for wires. I think though that orange is power...that was in my 99 and that was awhile ago....so double check me on that.
I dont see why your idea wouldnt work.
Old Nov 24, 2012 | 08:31 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Orange is power your right!
Old Nov 24, 2012 | 11:29 PM
neo71665's Avatar
Depends on the amp draw of the camera if it will work. If its too much for the system it will pop the fuse. You try to just add a bigger fuse you stand the chance of catching things on fire.
Been awhile since I've looked at wiring diagrams but if I remember that's a pretty loaded circuit. It might take it or it might not.
Old Nov 25, 2012 | 05:28 AM
^^^^good point on the amp draw...overlooked that.
Lance Cornelison
Tires and Wheels
Jun 24, 2014 01:04 PM
dano440
Mar 29, 2012 09:17 PM
blazin8556
May 13, 2010 01:07 PM
speedzonwheels
Aug 14, 2009 07:51 AM
Kenton
Tires and Wheels
Oct 18, 2006 10:11 AM
