Can't find the answer to my question
Old Nov 25, 2013 | 08:12 AM
Lance Cornelison's Avatar
Lance Cornelison is on a distinguished road
Default Can't find the answer to my question
I've searched and searched and read all the will it fit threads I can find, but still haven't found an answer. My question is will 265/70/15 tires fit on a stock 89 s10 blazer 4 x 4. I have 255/70/15s on now without any problems. Thanks for your help.
Old Nov 25, 2013 | 10:32 AM
Diaita's Avatar
Yes, they should fit fine, as long as you are using stock offset wheels.
Old Dec 1, 2013 | 01:18 PM
Thanks Diaita. I know there is not much difference in the two, but sooner or later you cross the line.
Old Jun 24, 2014 | 01:04 PM
For any of you out there keeping score at home, or just curious about how this came out, here's the story. I finally got my tires and had them installed. I went with General Grabber AT2 size 265/70/15 tires. I had an idler arm replaced and a front end alignment on my 89 s10 blazer 4x4. Everything is completely stock. It rides and drives like a dream, except I had front tires rubbing on both sides. The left side wasn't too bad. I found a bolt head for the inner fender the tire was rubbing on. Took the bolt out and problem solved on that side. Did the same thing on the other side and took care of most of it. I had to cut off the bottom of the inner fender and little of the opening at the bottom of the outer fender. Since I did this I haven't had it rub anymore that I know of. That is the story on my particular vehicle and the way it is set up.
mjr45
Nov 13, 2014 07:53 AM
stinz
Nov 25, 2012 05:28 AM
blazerJim1701
Jun 15, 2010 09:16 PM
speedzonwheels
Aug 14, 2009 07:51 AM
Spartan66
Aug 1, 2008 12:19 AM
