Someone please just answer this one question!
Old Oct 18, 2006 | 12:32 AM
Kenton's Avatar
Kenton is an unknown quantity at this point
Default Someone please just answer this one question!
I have searched on this forum and I have searched online but I cannot find just a strait answer! I don't know what all the numbers mean. Will rims off of a 2000 Jeep fit on a 96 Blazer 4X4. This is all i need to know! Please help me out here!
Thank you very much,
Kenton
Old Oct 18, 2006 | 12:58 AM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
Default RE: Someone please just answer this one question!
ok im not sure if it will but heres the basics of wheel and tire sizing:
say we have my stock wheels and tires.
on my tires, the numbers 235/75/15R are written. here's what they mean:
-235----this is the width of the tread/***** on the tire
-75-----this is the percentage of the tread/**** width that is equal to the sidewall height
235x.75= 176.25
-15R---this is the diameter of the rim the tire is made to fit. in this case it is made for a 15" rim
now on to wheels. these specs are usually engraved on the back of the wheel somewhere.
my stock wheels: 6"BS 5x4.75 15
6"BS-------this is the distance from the back of the rim to where the wheel touches the hub
5x4.75"----this is called the bolt circle. 5 is the number of lugs or bolts, and 4.75 is the diameter of the circle that they are cut on
(draw a circle with a 4.75" diameter and put five evenly spaced dots on her and there you are
15-----------once again, rim diameter.
hope that helps at least a little........im not 100% on this, but im pretty sure that the jeep rims are a different bolt circle, so simple answer; no they wont fit. [8D]
good luck!
Old Oct 18, 2006 | 01:03 AM
Hanr3's Avatar
NO!!!!!
The Jeep has a different lug nut bolt pattern. The lug nuts are the nuts that hold the wheel to the truck. The Jeep has five per tire, and so does the S10-Blazer. However the Jeeps lug nuts are spaced 4.5" apart, while the S10-Blazers are spaced 4.75" apart.
There are other GM vehicles that have the 5on 4.75" lug nut pattern, (5 lugnuts on a 4.75" spaced pattern).
Camaros, Firebirds, Corvettes, and a few others.
http://www.tirerack.com/wheels/tech/....jsp?techid=92
Old Oct 18, 2006 | 01:07 AM
Kenton's Avatar
82-03 BLAZER / JIMMY 4WD - Bolt pattern 5 on 4.75 in - lug nut size 12X1.50
99-04 WJ GRAND CHEROKEE - Bolt pattern - 5 on 5 in. - lug nut size 1/2
This is what I keep finding and with your explanation they won't fit. That sucks. I was going to be able to get a REALLY good deal on a set of rims and tires. Still might buy them to sell them for more though!
Thanks for your help! I really do appreciate it! Now I kind of half *** understand how the wheel sizes work!
Kenton
Old Oct 18, 2006 | 01:10 AM
Hanr3's Avatar
Check out that link I posted. It shows you how they measure the bolt pattern.
Pretty simple once oyu understand it.
Old Oct 18, 2006 | 01:13 AM
Kenton's Avatar
Yeah I was just reading that. Really simple once I seen it in a picture with an explanation! Thanks guys for the help!
Old Oct 18, 2006 | 10:11 AM
Well, I'm glad you 'finally' got your answer. But in the future, do NOT double post.
Ron Snell
Dec 21, 2012 10:21 AM
stinz
Nov 25, 2012 05:28 AM
eclark69
Jun 21, 2012 02:41 PM
janet7
May 24, 2011 02:16 PM
11Bravo
Jul 3, 2010 12:36 PM
