CB and radar detector
Old Nov 23, 2013 | 05:19 AM
Shadowdigger95's Avatar
Shadowdigger95 is on a distinguished road
Default CB and radar detector
Would I be able to run the hot and ground for a CB radio and a radar detector to the hot and ground on my stereo wiring kit? Or would it be more practical to wire one each to the accessory outlets with a switch? I can't decide.
Old Nov 23, 2013 | 11:11 AM
ol' grouch's Avatar
ol' grouch is on a distinguished road
They would probably draw too much amperage for the wiring kit and blow fuses left and right. Generally, when I add a lot of accessories, I'll hook into the accessory fuse for a trigger wire and put in a 30 amp relay. It will have plenty of capacity for just about anything shy of a huge monster amp and will draw straight from the battery.
Run a hot wire from the battery to the relay. Add a fuse in the circuit before the relay, I usually use a 25 amp for safety unless I need more. Then run a trigger wire off the switch so when you shut the car off, the power is off too. You now have a power supply for the detector and radio.
Old Nov 23, 2013 | 12:23 PM
cheapazz's Avatar
cheapazz is on a distinguished road
And if that doesn't work buy a 12V power supply splitter and just plug em into that. It just plugs into the cig lighter and splits off to 2 plugs. If the cb didn't come with the cig plug they are usually under $10 at most places, easiest to find at a truck stop and no cutting or splicing....just plugs into the radio.
trobbins
Jan 30, 2013 12:46 AM
shotnva777
19
Oct 4, 2011 04:48 AM
Ryanmatt135
Aug 29, 2010 06:35 PM
NTL1991
Dec 29, 2008 03:31 PM
Trikes17
Aug 29, 2008 03:53 PM
