Diaita's HID Retrofit
Old Feb 1, 2014 | 10:37 AM
  #31
Thogert's Avatar
Color flicker.
Old Feb 1, 2014 | 01:47 PM
  #32
KM346's Avatar
KM346 will become famous soon enough
Its really nice to see someone doing this the right way using projectors and not just stuffing them in the stock housings. Serious light output but a clean beam cutoff so you wont blind everyone. Well done sir.
Old Feb 1, 2014 | 02:02 PM
  #33
Diaita's Avatar
I despise when people put HID bulbs in halogen housings, and call it good enough. Sure it puts out more light, but it makes it no better on the road right in front of you where you need it. That said, I get satisfaction when I turn on the Rigids and can see their blinded reaction.
Old Feb 1, 2014 | 02:07 PM
  #34
KerbyG's Avatar
KerbyG is on a distinguished road
I'm glad these look as well as they do, both performance wise, and aestheticly. Proper installs for the win!
Old Feb 1, 2014 | 04:48 PM
  #35
richphotos's Avatar
Well, I know which projectors I will be going with, Real nice output.
Old Feb 1, 2014 | 06:51 PM
  #36
Diaita's Avatar
Alright! Pulled some screws, and did some baking.
Here's how the lights came:
Unclipped the chrome bezel, and removed the four metal clips that hold the lens to the housing:
Removed all the hardware from the back, put the headlight assy on a cookie sheet, tried(semi sucessfully) to explain to the better half what I was if to, and set the oven to 250F:
8 minutes in the oven, and a butter knife(pry tool) later:
After pulling the lens and black inside trim:
Attached Thumbnails Diaita's HID Retrofit-20140131_202322.jpg   Diaita's HID Retrofit-20140131_202656.jpg   Diaita's HID Retrofit-20140131_213907.jpg   Diaita's HID Retrofit-20140131_220222.jpg   Diaita's HID Retrofit-20140131_220844.jpg
Old Feb 2, 2014 | 12:08 PM
  #37
Thogert's Avatar
Haha, explaining to the other half what you're doing with the oven is the toughest part of the project.
Old Feb 2, 2014 | 02:40 PM
  #38
Diaita's Avatar
I tried explaining to her what I was doing. "Don't make a mess"
Anyhoo, I did get further the other night, but didn't upload pics...
This is with the original projector removed so you can see the reflector bowl:
I didn't take a picture of it with the 9005 bulb support parts, but I'll do that as I'm disassembling the other side and edit this.
Here is after I hole sawed the hole from the 13/16" to 1-3/4" for the projector base:
Still needs to be tidied up, but trying to make sure everything fits first.
It fits!
I had to sand out the hole slightly after the hole saw, but only slightly. The back of the Mini D2S 3.0 fits nearly perfect into the reflector bowl of the original. A bit of high heat silicone will set it very well, so very happy about that!
Attached Thumbnails Diaita's HID Retrofit-20140201_143641.jpg   Diaita's HID Retrofit-20140201_143625.jpg   Diaita's HID Retrofit-20140131_231216.jpg   Diaita's HID Retrofit-20140131_231144.jpg
Old Feb 2, 2014 | 02:43 PM
  #39
Diaita's Avatar
My biggest issue I'm having is the shroud...
Old Feb 2, 2014 | 03:00 PM
  #40
Thogert's Avatar
Yeah good luck with that part. I was lucky that my housings fit one of the largest shrouds without any trimming needed.
