Driver side headlight short...grr
Old Mar 27, 2011 | 11:20 PM
Fires_Sin's Avatar
Fires_Sin is on a distinguished road
Question Driver side headlight short...grr
Ok, so here is the deal. Since I bought my 2000 Blazer a few months ago, my drivers side headlight will only sometimes come on. If the headlight doesn't come on, I just get out and hit it, then it comes on. And when switching from hi beams back to lo beams, it sometimes turns off then comes back on in a few seconds. Anyone else has this problem, and how did you fix it? Thanks for your help.
Old Mar 27, 2011 | 11:43 PM
blue_zr2's Avatar
blue_zr2 is on a distinguished road
sounds like it could be a ez fix..
pull the bulb and check it you may have a bad filiment and when u have the lights on and hit the light they hit and turn on?
worth a shot to check thats what it sounds like
Old Mar 27, 2011 | 11:59 PM
Fires_Sin's Avatar
The light turns on some times, but when it doesn't all I have to do is give it a good smacking around and she turns right on. Going to take it out tomorrow, see if everything is making a good connection, probably put new bulbs in on both sides too, since one is dimmer than the other. Well, I will make my old man do this. Me and electrical stuff do not get along. HAHA!
Old Mar 28, 2011 | 12:04 AM
blue_zr2's Avatar
when u pull the bulb look at the filiment in there "the wire"
Old Mar 28, 2011 | 12:10 AM
Fires_Sin's Avatar
I will do that. Thanks for the advice. Hopefully, it is just an easy fix. Should be something simple since it is only the one headlight.
mamawolf70
Apr 10, 2020 10:44 AM
cory30189
Dec 25, 2012 08:12 PM
OILCOUNTRY
Mar 30, 2010 06:28 AM
king22
Sep 8, 2009 11:29 PM
chris015
Sep 6, 2009 09:32 AM
