Fuel gauge doesn't go below 1/4 stepper motor replacement?
Old Dec 15, 2021 | 11:50 PM
CODEE_'s Avatar
CODEE_ is on a distinguished road
Default Fuel gauge doesn't go below 1/4 stepper motor replacement?
In my 03 blazer Ive had this issue of the gauge not going below 1/4 and runs out of fuel at said 1/4 for a while .What I've done is change the pump/sender assembly,rerun purple and both black wires and still won't go below 1/4 tank and that's where I run out of gas. The only thing I could think it would be is a bad stepper motor. Anyone have any ideas ?
Old Dec 16, 2021 | 09:46 AM
It sounds like the zero of the gauge on the instrument panel is set wrong.
You could eitber live with it and not forget that "1/4" = empty or you can get a replacement gauge panel from a wrecking yard and install it.
If you swap out the whole gauge panel the odometer will be off. I know this as I did this when my speedometer gauge would stick.
You also might try swapping the gauge in the gauge panel.
snapper86
Oct 13, 2020 03:55 PM
El_Beautor
Sep 19, 2012 12:49 PM
sleonh
Sep 22, 2009 07:15 PM
sobtom
Aug 11, 2008 07:56 AM
ned4spd8874
Mar 6, 2008 09:40 AM
