fuel pump voltage
Old Aug 28, 2013 | 06:00 PM
59bigdogs's Avatar
59bigdogs is on a distinguished road
Default fuel pump voltage
is there a way to put 12 volts to the fuel pump with out going thrue the wireing harnes on a 98 chevy blazer 2 door v- 6, I have had 2 fuel pumps
go bad and now another, so am trying to isolate to see if it is a elect. problem.or another bad pump, witch have been delfi pumps, I have also replaced plugs, wires, cap& router and fuel relay just to rule them out, I can't find info on recall's but 3 bad pump's ?.
The blazer will start after I put a little gas in the carb. and run fine but not after I turn it off and it only has 42psi. be for I try to start it and 61 after it run's .
Side note - the flasher unit behind the glove box keep's going off unless I but my foot on the brake?
Thank's for your help if you know
Dale
Old Aug 28, 2013 | 06:11 PM
coolasice's Avatar
coolasice will become famous soon enough
what brand pumps?
Old Aug 28, 2013 | 06:28 PM
59bigdogs's Avatar
Delfi pump
just a note I have found swartikk's post on fuel system diagnosis and am looking at those possabilites
Last edited by Thogert; Aug 28, 2013 at 10:12 PM. Reason: Combining consecutive posts. Please use the edit feature.
Old Aug 29, 2013 | 02:47 PM
coolasice's Avatar
did you change the fuel filter when the pump was changed
Old Aug 29, 2013 | 07:40 PM
59bigdogs's Avatar
yes i did,both times
Old Aug 29, 2013 | 09:35 PM
coolasice's Avatar
no idea then..maybe someome else will chime in
Old Aug 30, 2013 | 12:44 AM
richphotos's Avatar
There should be a spot in the engine bay to put a jumper wire to add 12v to the fuel pump (its the fuel pump test area) I am not sure where that is, as I do not own a 2nd gen. someone should know.
Old Aug 31, 2013 | 01:19 AM
abig84's Avatar
i guess the PROPER way of doing it is to buy a relay jumper kit and jump the relay to power the pump. had to do lots of that when we had a plague of bad gas in the area last year. it was either that or just use a power probe and power the wire going to the pump by the tank
RJWolfe
Feb 17, 2019 07:32 PM
NV4x4BLazer00
Mar 10, 2012 08:57 PM
2001Blue
Dec 31, 2010 12:16 PM
cjp5
Sep 15, 2010 07:51 AM
c4gibson
Apr 4, 2008 10:49 AM
