Ground wire for Transfer case motor on 99 blazer
Old Oct 8, 2022 | 09:19 PM
AquaAngel's Avatar
AquaAngel is on a distinguished road
Default Ground wire for Transfer case motor on 99 blazer
Does anyone knows where the main ground wire for the transfer case motor is located? i was able to do some massive work on the blazer today with a new fuel pump, new ignition system, new cooling system, new brakes and all and i did clean one ground wire on the passenger side on the frame by the transmission cooling line, but that didn't solve the 4wd problem, however ...... i did notice "as it was getting dark" that the lights were dimming when i click the 2HI and i can hear the motor trying to engage but it won't, leading that it will be a bad ground wire "assuming that it is"
Any help will be greatly appreciated.
Thank you
Old Oct 9, 2022 | 02:22 PM
GeorgeLG's Avatar
Here is your circuit diagram(s).
George
File Type: pdf
File Type: pdf
Old Oct 9, 2022 | 06:57 PM
AquaAngel's Avatar
Smile
George
Thank you very much sir.
AquaAngel
Oct 8, 2022 10:26 PM
Keystoneguy91
Oct 30, 2012 08:44 AM
JerryB52
May 16, 2011 11:34 PM
96chevblazer
Aug 3, 2009 04:02 PM
coolbrother2002
Jun 14, 2008 07:10 PM
