Headlights flickering
Old Jan 21, 2017 | 08:06 AM
Fire_blazer's Avatar
Fire_blazer is on a distinguished road
Default Headlights flickering
I have a 98 Blazer 4 by 4 for some reason the high life will be working fine then it was tough flickering I'm forced to use high beams have anybody experience this problem or no what the fix will be? Or do I just need new headlights or bulbs
Old Jan 22, 2017 | 11:03 AM
Can someone help?
Old Mar 26, 2017 | 03:10 AM
Mitchell_Roadside_Tech's Avatar
Mitchell_Roadside_Tech is on a distinguished road
Yes my blazer did the same thing and then finally stop working and was forced to run high beams as well..I just found my problem after tearing out the dash, under the hood on the driver side is a main fuse block the problem is located in side and I found that my wires are burnt. To access this you must disconnect the battery and remove the bolts holding the block down pull it up carefully and turn it over you'll see four blocks connected remove the green block by removing the bolt and gently pry the block out and you'll see your problem right away, I'm going to clean the wires on mine and replace it in another fuse port. I hope this helps.
Wheel Team 6
Nov 7, 2016 06:13 PM
RT Dave
Mar 6, 2014 12:06 PM
04zr2blazer
Feb 10, 2013 05:23 PM
lemon blazer
Feb 2, 2008 05:13 PM
USMaverick101
Mar 28, 2007 07:55 AM
