Headlights low beam problem
Old Jan 14, 2011 | 08:41 AM
dkatz's Avatar
dkatz is on a distinguished road
Default Headlights low beam problem
My headlight low beam stopped working some time ago. when i use the stalk to switch on the High beam they come on. I've tested the the high beams with a volt meter ant they show 13.4v. My low beams show nothing when switched on but show 30v !!! when the high beam is switched on. The lamps are all fine. I cant find a fuse or a relay. Please advise.
Old Jan 14, 2011 | 08:53 AM
Vehicle info? Please include this basic information in EVERY request for help.
Old Jan 14, 2011 | 03:19 PM
dkatz's Avatar
My apologies
Its a 1995 Chevy Blazer 4WD
Old Jan 27, 2011 | 12:38 PM
ChevyFamily's Avatar
ChevyFamily is on a distinguished road
Got a similar problem with my 97, only the driver side low beam isn't working. Did you discover your problem. Was your problem on both sides?
Old Feb 20, 2011 | 07:47 PM
bajabound's Avatar
bajabound is on a distinguished road
Default same here
1994 full size. have the high beams but no low beams. bulbs are good, replaced the switch, anyone with what to do next?
Old Feb 21, 2011 | 11:37 AM
Mine ended up being the bulb after all. You check the relays? They are in the glove box on my model.
Old Feb 21, 2011 | 11:46 AM
bajabound's Avatar
Yeah, been in the glovebox too. I have to figure its in the stalk on the column as my wipers, washer and cruise are out as well. Is there a how-to here on diassembly of those?
Old Mar 2, 2011 | 06:44 AM
Your truck really isn't a K5 blazer in the purest sense (SFA == K5 vs IFS =/= K5) and there are a lot of differences between your truck and the K5's (1st gen 69-72 & 2nd gen 73-91 vs 92+) in this regard. As such, there isn't a lot of information here about your truck. We can try to help, for sure, but please try to post up in the appropriate manner (i.e. not piggy backing off of a thread that is on a very different vehicle).
Mike4x4ing
Jul 6, 2013 01:21 PM
marine
Jan 28, 2010 07:05 PM
dimmuborgir6nik6
Feb 27, 2008 01:34 PM
khalid_20879
Dec 28, 2005 08:47 PM
AzBlazer
Jul 3, 2005 04:17 PM
