how many amps does a alt put out at idle
Old Oct 16, 2009 | 06:43 PM
ExplicitYourSelf's Avatar
ExplicitYourSelf is on a distinguished road
Default how many amps does a alt put out at idle
i have a 01 chevy blazer 4dr and i was curious how many ampp does it put out at idle and how many while driving if there is a difference.
Old Oct 16, 2009 | 06:52 PM
Max output should be 105A (could be 100A if you have the smaller alt - your RPO codes should tell you which one). As far as at idle vs at speed, I do not know how they are rated.
And one thread is enough. Double Posting is against forum rules. If you think you may have posted in the wrong section, a member of the staff can and will move it for you.
*Moving to Audio/Visual*
Old Oct 19, 2009 | 12:45 PM
the reason i ask is becuz i have a 1000w rms audio system and im having issues with my sub it cuts off when i turn up the volume.i notice that it drops to 13.8v and when the music is off its at 14.3v.i do have the big three upgrade done with 1/0 gauge ofc power cable.
Old Oct 19, 2009 | 02:38 PM
nj4x4blaze's Avatar
Double check your power wire running to you amp. I had this issue last year and it turned out the power wire connecting to the fuse in the engine bay was loose.
Old Oct 19, 2009 | 05:07 PM
I will check that when I have a chance... All my grounds have good contacts to metal/chassis (sanded chassis before placing ground cable). Is the stock alternator good enough to power my thousand watts rms?
Old Oct 20, 2009 | 02:47 PM
hubbmatt's Avatar
hubbmatt is an unknown quantity at this point
Could be due to your amp starving itself. My 1400.2 had (2) 30A fuses in it for each channel. I talked to a buddy of mine at the local Car Audio shop and he said "true" multi-channel amps will cut-out for whatever channel you pull the fuse at, i.e.-if you pull the RT channel fuse you'll only have sound coming from the LT channel. Cheaper amps will have multi-fuses but the power block is bypassed through each channel, i.e.-if you pull any fuse and leave one in you'll get full sound @ all speakers. This is a problem cause when you figure the power you can only factor in 1 of the fuses. Mine was rated @ 350Wx2@2ohms, but with only 1 "real" fuse i was getting closer to 175Wx2@2ohms. Don't know if any of this is correct but when I get the new amp (old one fried!) it had (2) 40A fuses @ true 2 channels. Hasn't done it since.
Old Oct 20, 2009 | 11:54 PM
my kicker amp has 240A fuses, so what i pretty much need is alot more current and that is why my amp is starving? i have ofc 4 gage running from the battery (front) to the back to a distributor block and then 4AWG to each amp
Old Dec 13, 2010 | 11:50 PM
whiskeytim's Avatar
whiskeytim is on a distinguished road
your alt should be fine. fuse, wire gauge fine. do you have a cap at least
1 farad? or a optima yellow cap battery wired in paraalell with your main batt. with an isolation relay? the ALT. is more than likely fine. it can re-charge faster than you think. its your amp draw. and you dont need even 60 amps to see a diffrence in you vehicle. the 250 amp fuse is just for protection to your batt. so if you have a short you dont spew sulfuric acid all over. you dont have a "Overwhelming" system so I would go with some buffering in the power delivery. ie. cap, or switched batt.
I bet even a 1/2 farad cap would do you wonders. its like a resivor of power, it draws from the cap instead of your batt.
or your speakers are wired for a load the amp cant handle, not many amps can really handle a contunious 2ohm load, maybe for 5% of the duty cycle but not all the time. fooling the consumer saying it 2ohm rated.... for 5% of the time .........3 min. of every hour. if you have a dual 4ohm coil sub wired in parrellel its a 2 ohm load +/- 3ohm per waveleingth. for every 1 sec. your giving that amp anywhere between 5 ohms and a -1 ohm (direct short on voltage rails in amp) witch would result in the amp going into protect mode.
shade tree
Feb 1, 2022 06:48 PM
Blazer51
13
Jul 14, 2012 06:03 PM
bdepue
Dec 27, 2010 03:05 PM
ExplicitYourSelf
Oct 16, 2009 06:54 PM
Scooterewski
Mar 24, 2008 08:16 PM
