Ignition Tumbler?
Old Feb 15, 2025 | 03:25 PM
zrex2's Avatar
zrex2 is on a distinguished road
Default Ignition Tumbler?
So I just replaced the ignition switch on my 97 Blazer. After I did this it started just fine, but then it wouldn’t start anymore. If i take the little black ignition switch box off and turn it with a screwdriver it starts right up just fine. Could this be a problem with the ignition tumbler? I’m wondering if it’s just not turning the switch enough to start it.
Old Feb 15, 2025 | 09:45 PM
zrex2's Avatar
Just gonna leave this here in case anyone has the same problem. It did end up being the ignition cylinder. You can pop it out with a pick and test it by sticking something in the part of the steering column where the cylinder goes and turning it. I used the closed end of a combination wrench but you could also use a large flat blade screwdriver or something like that. If the car starts just fine every time, the issue is likely the ignition cylinder.
hbs20
Oct 17, 2015 03:02 PM
blazertom
Aug 21, 2015 11:16 PM
tony991
Apr 17, 2013 07:13 PM
socal nick
Mar 7, 2012 05:14 AM
tmdriverwannabe
Oct 17, 2011 08:12 PM
