Key Stuck in Ignition! After Replacing Radio
Old 11-11-2011, 08:19 PM
matt94's Avatar
matt94 is on a distinguished road
Lightbulb Key Stuck in Ignition! After Replacing Radio
I just finished replacing the stock radio on my 98 Blazer 2dr auto, and the key is stuck inside the ignition. I can turn the key to turn on the power and the engine starts with no problems, however, it won't turn back far enough to release. It won't turn back to the last position where you can pull it out. Any ideas?
PS-The transmission is firmly in park.
Old 11-11-2011, 08:26 PM
warthogdriver's Avatar
Old 11-11-2011, 08:40 PM
matt94's Avatar
Hmm well this is the first time it's done it, and the person in that thread describes it as an "occasional" issue, so I think I'll play around with it. But is there any security lock system that could've been tripped when I was installing the new audio system? (the battery was dis/reconnected a few times)
Old 11-12-2011, 10:26 AM
matt94's Avatar
So now the key will turn to the lock postition, but it still won't release. At least now I don't need to disconnect the battery to prevent it from going dead. I'd still like my key back though!
It let go overnight... Hopefully it doesn't do this again.
Last edited by swartlkk; 11-13-2011 at 06:39 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
bigjblaze
10-19-2009 07:11 PM
trettifire
10-03-2009 08:48 PM
Woods1478
04-25-2008 08:57 PM
klein
05-05-2007 04:03 PM
will5631
03-27-2007 10:50 PM
Quick Reply: Key Stuck in Ignition! After Replacing Radio
