Lighting problems
Old Feb 9, 2014 | 12:53 PM
beardface's Avatar
beardface is on a distinguished road
Default Lighting problems
So all these problems started at the same time about a week ago.
'91 s10 Blazer
-Driver side tail light doesn't work at all (turn signal, tail light, brake light, etc.)
-When I press the brakes all my marker lights and my instrument lights turn on.
-When my headlights are off and I turn on my right turn signal, all my marker lights blink (as if my hazards were on)
-When my headlights are on and I turn on my right turn signal, the light comes on but doesn't blink.
-Interior lights keep blowing fuses (not sure if related)
I don't even know where to start...
Old Feb 9, 2014 | 01:34 PM
richphotos's Avatar
You should have just added this to your other thread you started, instead of making a new post.
as for your tail lights and exterior lights doing weird things, did you happen to replace a bulb recently on the side that does not work?
Old Feb 9, 2014 | 01:47 PM
beardface's Avatar
No. The only thing that had been done recently is I welded on a roll pan. I cut off the plug where you would plug in a trailer... would that affect it?
Old Feb 9, 2014 | 05:37 PM
rockp2's Avatar
Did you seal the ends of the wires you cut or just leave the ends bare?
Old Feb 10, 2014 | 08:14 AM
richphotos's Avatar
That is where I would start than, Sounds like something is shorting out back there since you cut the plug off.
MyWorkInProgress
Feb 7, 2015 03:57 PM
zister
Jul 14, 2014 02:55 PM
bigt
Mar 18, 2008 05:22 PM
eslhockey92g
Oct 13, 2006 10:11 AM
idr
Mar 13, 2006 12:33 PM
