LS LT SLE steering wheel radio controls.
Old Jan 24, 2021 | 06:10 PM
Monkeywrench71986's Avatar
Monkeywrench71986 is on a distinguished road
Default LS LT SLE steering wheel radio controls.
Saw some questions if the 00-05 supported the wheel controls. The answer is yes. Pics attatched are components pulled from a 01 Jimmy and proper clock spring w numbers location of connector for power and lighting. This is plug and play other than behind wheel trim the rear airbag cover supports buttons to prevent breaking. All parts were s10/blazer/Jimmy parts, wiring colors change at bottom of column from yellow green brown and black to blue black brown and Grey and are supported all the way to radio connector. There is zero cutting splicing solder crimp or modifications. If your blazer had steering wheel illumination fuse 2amp last fuse top rh side the wiring exists.
controls, location of main connector bottom of main ignition break out. Clock spring and illuminated
Old Jan 25, 2021 | 10:43 AM
I had steering wheel controls in my 2000 until the clockspring broke and I couldn't find a new one to save my life. Not really a big deal since I hardly ever listen to the radio while driving my Blazer, anyway.
Old Jan 25, 2021 | 02:27 PM
Thanks for this... was looking into getting this done...
Old Jan 25, 2021 | 07:07 PM
Great photos. One of the first things I did to my 04 when I got it it needed the steering wheel replaced anyhow, it was pretty worn out...
Old Jan 25, 2021 | 10:48 PM
eshaw's Avatar
That's a great looking wheel.
Jimmy4x4
Jun 18, 2020 03:41 PM
blazen_red_4x4
Oct 28, 2017 09:27 PM
serrasalmus
Mar 4, 2012 06:32 PM
01BlackBlazer
May 15, 2010 09:17 PM
DaveC
Apr 7, 2010 07:33 PM
