my dome lights wont shut off.
Old Oct 30, 2014 | 06:01 PM
mjallen's Avatar
mjallen is on a distinguished road
Default my dome lights wont shut off.
I have a 99 jimmy and the dome lights wont shut off .unless I shut off the override switch .I have no switches on the hatch or glass all the door switches good.But on front pass side has no wire and can not find a wire.
Old Nov 4, 2014 | 11:29 PM
cleburne red's Avatar
When you say override switch, do you mean the one in the back, next to the rear dome light? I'm not sure how your 99 differs from my 95, but I had a problem where the switch for the rear glass wasn't being fully depressed, and the dome lights would stay on.
Old Nov 5, 2014 | 07:04 PM
mjallen's Avatar
no its a button on the dash I have no shut off switch in the back.
Old Nov 5, 2014 | 11:24 PM
odat's Avatar
As maybe you know its a ground system - you stated you have a switch without a wire on it - its more than likely that it's there somewhere and grounded out - look well behind the kick pannel beside your feet under the dash, it could have worked it's way under carpet, into body pannels ect.- my 97 blazer LS also has a switch's at the door handles. if yours has the same one of them could be bad also
kathyrook
Oct 7, 2014 05:12 PM
dlmallory
Feb 21, 2012 09:54 PM
chester92
Nov 14, 2011 02:50 AM
dimone545
Aug 25, 2009 02:19 PM
Melodyjn
Jan 12, 2007 09:24 PM
