need help designing a circuit
Old Nov 7, 2011 | 08:41 PM
cimbaliw's Avatar
cimbaliw is on a distinguished road
Thanks PettyFog. I don't know much about electronics, but I like the no switch diode design. Man I just don't have the smarts for that kind of stuff. Anyway is there a way to tap the radio acc/run lead without removing the head unit? I installed an AVIC 310 BT last year. I know it's not hard to get behind the radio but I'd rather not if I don't have to.
Old Nov 8, 2011 | 04:17 PM
pettyfog's Avatar
I dont know about your 2004 but on my 99 switched radio pwr is dark green goes directly from IP fuse 24, 10 amp to radio.*
Drk green also goes up the driver side pillar to the driver info harness.
Just put a tap on the wire and check that it works in run/accy and doesnt work with radio fuse out
*according to alldata diag
Old Nov 9, 2011 | 09:33 PM
FsTFwRd's Avatar
Originally Posted by pettyfog
court sw + |>| {join}
Radio Accy/run + |>| {join}
{join} led array gnd
What in the hell? Did I miss something here hahaha. Are you refering to the diode, or the LED bar? Anode, Cathode.. Obviously I've missed something.
__________________________________________________ _________
A Because picasa isnt an image sharing site. Or if they changed, your setting are wrong.
- just checked in my albums.. nope, you can only do 'click-link to' or email.
For postable pics use imgur or photobucket NOT imageshack.. near malware on there I'm pretty sure.
B @!$@#@# I havent been on picasa for years, and never on this machine and it still auto logged me in!!!!
- Wrong. It just used my last google ident.[/quote]
Old Nov 10, 2011 | 12:41 PM
pettyfog's Avatar
Is this better? Squint and you'll see a diode symbol They refer to the 4002 blocking diodes.
{Join} refers to common point of the 4002 cathodes and wire to the + lead of the LED array.
court sw + -|>|- {join}
Radio Accy/run + -|>|- {join}
then {join} led array gnd
PS: My suggestion might not work. Just found from looking at lights circuit for another reason that courtesy circuit switches gnd, not positive
Old Nov 11, 2011 | 11:02 PM
FsTFwRd's Avatar
Hahaha, ok I see it now. I didn't know what the hell I was lookin at.
NVANZEE
Apr 10, 2011 11:20 PM
jamez70
Performance & Brainstorming
Sep 29, 2009 12:19 PM
rwrows
Apr 5, 2008 11:01 PM
alphawhisky
Jan 14, 2007 12:16 PM
a_tack
Dec 24, 2006 01:30 PM
