Need help with interior LEDs
Hey, I built an LED light module and I am having trouble getting it to work with the car. I spliced into the wires going to the light socket that I am replacing. The LEDs come on when the car has been sitting a while, but not when it is on, or recently turned off.
Here is my circuit:
The wires from the driver side courtesy light go to a 7805 5V+ regulator. On the other side of the regulator are LED's with proper resistors in parallel.
I am guessing that the regulator is making the PCM think the bulb is either out or shorting, not sure which... or how this stuff works. I noticed something weird, when the circuit is on there is 0V on the negative, when the circuit is off, there is 12V+ on the negative... Any thoughts, suggestions or warnings?
Thanks!
Regards,
Thomas
Here is my circuit:
Thanks!
Regards,
Thomas
Why are you using a regulator? All you really need is the correct resistors... Like my dome light is 4 leds in 2 pairs, each pair has a 270 ohm resistor. Works fine every time and has alot less that can go wrong with it.
eddy78741
Sep 19, 2013 03:14 AM
S10Blazer
Jan 29, 2008 01:29 PM
