need some advice on a 95 4.3 v6 blazer
Old Feb 27, 2011 | 07:09 PM
jfurgason2686's Avatar
jfurgason2686 is on a distinguished road
Default need some advice on a 95 4.3 v6 blazer
Ok everyone my names jason and I own a 95 chevy blazer with a 4.3 fuel injected motor. I have a problem starting my truck. When I turn the key over I can hear the fuel pump whine but when I start the truck the relays in my passenger side glove compartment click. I have replaced them thinking that they were bad but when I put the new ones in it still did the same thing. I have changed cap and rotar replaced both map sensor and computer. And still no luck. Can anyone shed some light. I have a chiltons book but no such luck. Help please
Old Feb 27, 2011 | 07:58 PM
Given the fuel supply problems that plague so many CPI engines, I would start with a fuel pressure test. The fuel pressure test port is located on the fuel supply line where it goes through the lower intake manifold into the inner plenum. It is between the distributor and the brake booster on the back of the intake manifold.
Your engine requires >55psi to properly run. A fuel pressure gauge is necessary to read the fuel pressure.
iamthesargent
Engine & Internal
Aug 31, 2011 02:27 PM
dinomotz19
Oct 26, 2010 08:39 PM
94driven
Nov 14, 2009 12:43 PM
tomtom9649
Nov 2, 2009 09:34 PM
rcravincase
Sep 13, 2009 07:58 PM
