No headlights after motor swap?!?
Old Oct 19, 2015 | 03:35 PM
87Beamer's Avatar
87Beamer is on a distinguished road
Default No headlights after motor swap?!?
So here is the deal, I've been dealing with a failed motor swap. My buddy has a shop and had one of his new guys test out his skills on my blazer. He failed. We finally got the new motor in but I don't have high or low beams everything else works tho. I checked the bulbs the fuses on the inside of the truck but I get nothing. Before I go out and fiddle with it I just wanted to know what your guesses were as to what's going on. Thanks for the input.
Old Oct 19, 2015 | 06:47 PM
richphotos's Avatar
Year and model would make this a bit easier, since wiring changed through the years.
Old Oct 19, 2015 | 06:56 PM
87Beamer's Avatar
. Sorry man, 98 2door 4wd non zr2 v6
Old Oct 19, 2015 | 09:29 PM
odat's Avatar
Check for ground wires that did not get reattached - firewall, radiator support, fender wells, engine, ect.
Old Oct 19, 2015 | 11:34 PM
richphotos's Avatar
wasnt the headlights in that year + grounded by the BCM? I might be mistaken.....
Old Oct 21, 2015 | 12:43 PM
87Beamer's Avatar
Okay, so I checked and there is a ground right by where the harness connects to the headlight on both ends and they were nice n clean n tight. I can recheck fuses. I did notice that the passenger DTRL was clipped would that cause an issue? Keep in mind this is low beam and high beam on both sides and no dtrl either.
Jimmybeatergal
Mar 21, 2014 07:24 PM
Daniel Wood
Mar 17, 2014 04:05 PM
Charlie99
Jul 10, 2013 07:02 PM
hollywoodgrad
Jan 25, 2012 01:58 PM
EuroGoldLS
Jun 3, 2007 04:50 AM
