No headlights!!!HELP PLEASE
Old Sep 16, 2021 | 07:21 AM
  #111
GeorgeLG's Avatar
Keep us posted on what you find and good luck.
George
Old Sep 3, 2022 | 05:01 PM
  #112
Blazermama00's Avatar
Blazermama00 is on a distinguished road
Hey George!! Hope all is well. So I didn't find any issue with wires etc. Ran a fused wire toggle like you posted from the relay. New thing happened with the headlights..... I applied the brake and put it in D and they came on for a brief 10 seconds and went off. This was at night before I could even hit the toggle switch to activate. Any idea if something connected to the steering column or brake pedal could cause for them to come on.
Old Sep 4, 2022 | 08:50 AM
  #113
GeorgeLG's Avatar
So you did the jumper wire and toggle switch hack to get your headlights working and this has been working OK? Does anything else go wonky besides the headlights when you press on the brakes? Does it also have to be moved into D as well as the brakes or either will make the headlights come on?
offhand, three possibilities come to mind. A power wiring short in a harness, a bad ground, or a bad BCM. List everything that acts wonky.
George
Old Sep 4, 2022 | 05:26 PM
  #114
Yes that has been working just fine. No other things go wonky. I tried all other gears and lights did not come back on. Last night at dusk I went over some bumps and the headlights briefly came on.
Old Sep 4, 2022 | 07:49 PM
  #115
GeorgeLG's Avatar
You must have a corroded wire harness somewhere, most likely in/under the dash. Look for any white or green powder or bulging harness indicating corroded wires. Start at the brake switch going up and the headlight switch heading into the dash. Have you ever had a door or windshield leak?
George
Old Sep 5, 2022 | 04:01 PM
  #116
No powder or bulging. Yes my windshield did leak on the passenger side
Old Sep 5, 2022 | 04:04 PM
  #117
GeorgeLG's Avatar
I forgot to suggest watching the headlights while moving those wring harnesses around to see if anything happens.
George
Old Sep 5, 2022 | 04:19 PM
  #118
Yes I had someone watch while I did that and headlights did not come on.
Old Sep 5, 2022 | 06:09 PM
  #119
GeorgeLG's Avatar
If there is no corrosion/wiring short then I see three possibilities:
A ground problem
The multifunction switch
The BCM
Have you had any problems with either of these three?
George
Old Sep 5, 2022 | 06:13 PM
  #120
I was thinking possibly a ground. Where would be best to start?
multifunction switch I replaced
BCM I'm not sure. I would think other problems would be happening and not just the headlights, but I could be wrong.
