No headlights!!!HELP PLEASE
Old Sep 5, 2022 | 06:14 PM
  #121
Blazermama00's Avatar
Blazermama00 is on a distinguished road
I did notice on my headlight the pigtail was burnt on one side I am going to replace that tonight
Old Sep 6, 2022 | 09:31 PM
  #122
GeorgeLG's Avatar
Originally Posted by Blazermama00
I was thinking possibly a ground. Where would be best to start?
multifunction switch I replaced
BCM I'm not sure. I would think other problems would be happening and not just the headlights, but I could be wrong.
G114 left rear engine
G117 right rear engine
G100 front of left front fender
G202 left center dash
G201 right side dash
G108 left radiator support
G109 right radiator support
George
Old Sep 30, 2022 | 06:13 PM
  #123
I believe I found the problem!! I took the UHFB to check the pins and found melting on the surrounding of the wires. Peeled it back and I believe 2 or 3 wires have melted themselves together.
Old Sep 30, 2022 | 06:19 PM
  #124
GeorgeLG's Avatar
That might be the infamous white headlight relay control wire that you bypassed before.
George
Old Sep 30, 2022 | 06:38 PM
  #125
I believe it may be. My fuses kept blowing too to run the toggle switch. Now I am currently taking the qtr panel off, it's a tight squeeze to try and manage getting to them wires. Going to be a long fun Friday night. But just wanted to let you know what I found. Will keep you posted.
Old Sep 30, 2022 | 08:53 PM
  #126
Qtr panel off(NOT fun)and pulled back the tempered tape and found 3 melted spots. I am at a loss for words. What could of caused this if you could of anything?
Old Sep 30, 2022 | 09:36 PM
  #127
GeorgeLG's Avatar
Usually leaking water, sometimes chewing animals like rats. Also shoddy repair work but that all looks OEM and not repaired, just corroded.
George
Old Sep 30, 2022 | 10:56 PM
  #128
Problem wire!! Unsure what color it was since it gone. Now how do I remove it to replace that wire alone?
Old Oct 1, 2022 | 11:38 AM
  #129
GeorgeLG's Avatar
Which connector is that? Are you missing a wire completely so you have no idea where is goes or you are missing the wire color so it’s there but you don’t know what it does? Usually the connector pin pushes in and snaps into place in the connector and you have to depress the tangs to get it out to solder a new wire on before pushing it back in. There is a little tool for this that workers on some of them.
George
Old Oct 1, 2022 | 02:57 PM
  #130
This connector is from the UHFB to the firewall/inside dash. Followed the wire further and it was a yellow one. Just that wire was melted completely. It fused together with other wires as it melted but did not harm any other wire. I stayed up until 6a finishing this. I have Headlights now!!!
