no lhs low beam
Old Aug 29, 2011 | 10:22 AM
blazer2554's Avatar
blazer2554 is on a distinguished road
Angry no lhs low beam
Hi,i tried to do the quad beam mod on my 98 blazer by grounding out the yellow wire on the driver's side(rhs drive) but my lhs low beam wasn't working,then i grounded out the lhs yellow wires(2 on the low beam)one at a time,but now the problem is that i'm not getting power to last mentioned 2.i've checked the fuses but non were damaged.please help.
Old Aug 29, 2011 | 03:20 PM
On the '98's, there are two yellow wires to the left low beam and one on the right (driver side for RHD). The ground wires run together in the underhood fuse/relay center. Grounding the yellow wire on the right side should accomplish the same purpose as grounding the appropriate yellow wire on the left side. This will result in your low beams being on whenever the headlamp relay is energized instead of switching off when the HI beams are selected by clicking the multifunction switch on the steering column.
Did you cut the wires prior to grounding them? All that should be necessary is exposing the wires by removing the insulation & soldering the new ground wire in. That part is very important.
THIS POST has the schematic applicable to your '98.
Old Aug 29, 2011 | 09:23 PM
98blazin's Avatar
98blazin is on a distinguished road
i just did the quadbeam mod on my 98 blazer. i started by grounding the yellow wire with NO black line on the rad support. it worked but my low beams were always on and AHL didnt work.
so i installed a relay with a switch on the yellow ground wire so that i can active the quadbeam only when i want to at night.
Old Aug 30, 2011 | 03:17 AM
blazer2554's Avatar
I just spliced through the insulation,no cutting were involved,it worked the first time but the lhs low beam was very vague,then it blew a fuse,after replacing it no power came through on both yellow wires on the lhs low beam almost like the current is broken.is there maybe another fuse/relay i need to look at.i'm dumbstruck.
Old Aug 30, 2011 | 06:50 AM
You're going to have to start testing continuity on wires using the schematic in the link I provided above. Sounds like you shorted out a wire and have potentially melted something in the process.
Old Dec 3, 2011 | 09:53 AM
87yellowsuzi's Avatar
87yellowsuzi is on a distinguished road
Any luck on what was going wrong. Mine done the same thing. And I still haven't figured it out
Mike4x4ing
Jul 6, 2013 01:21 PM
marine
Jan 28, 2010 07:05 PM
dimmuborgir6nik6
Feb 27, 2008 01:34 PM
khalid_20879
Dec 28, 2005 08:47 PM
AzBlazer
Jul 3, 2005 04:17 PM
