no power to rear hatch
Old 02-12-2010 | 03:30 AM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
I was going on your ride being a 2002. Not sure on a '95, sorry. 98+ have a second fuse panel just forward of the ABS on the driver's side.
Old 02-17-2010 | 01:03 AM
Cuddie's Avatar
Cuddie is on a distinguished road
Check the wiring at the hinge on the back door/window, it's exposed to the elements and gets wiggled back and forth everytime you open it up. The harness at that point could be damaged, maybe not even visibly. If it's everything in the back door i would start there.
Old 02-17-2010 | 11:28 AM
Benedict1337's Avatar
are you sure its getting no power at all? because I had the same problem with mine but mine sounded like it was trying to pop the hatch but it sounded like it didn't have enough "power". I also thought that it was a wiring/fuse issue because it happened right after my alternator went out. After messing with all the wiring and fuses with no luck I took the plastic pannel of the trunk and took a look. What happened to mine was the little plastic piece that unlatched the hatch broke off so when I was pressing the button the mechanism was working but the plastic hook was broken. What I did was just screwed a metal hook into what was left of the broken plastic and hooked it into the latch. It have been working great ever since.
Old 02-17-2010 | 10:29 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Haven't heard anything out of them in a couple of days. Probably got it fixed. Just like most of them. You never hear from them again so you really don't know one way or another.
Old 03-09-2010 | 08:38 PM
dbosse2002's Avatar
dbosse2002 is on a distinguished road
got it figured out it ended up being the ground, thanks for all the advice
tmar89
04-23-2013 11:23 AM
RoxStar33
11-26-2012 08:46 AM
Wexinlo
06-08-2012 03:46 PM
1baggedblaze
04-13-2010 05:52 PM
Ever Thus
06-21-2009 05:20 PM
