Obd 1.5 paperclip trick?
I don't know which orange wire is in pin 16. Why you grounded it doesn't matter now. Yes, 12 volts is required for testing. Put the battery on a charger and start checking all your fuses. Sniff around for anything burned.
Your dedication, hard work, willingness to learn is admirable. You've proven yourself as "tha real". I'm a fan.
Respectfully, when you're not sure about something, please stop. You're dealing with very dangerous situations. Wet cell batteries can explode, blowing acid everywhere. Electrical problems can catch fire. Put them around fuel and adding starting fluid into the mix increases the risk exponentially.
I don't want to start a thread on this. But everybody has a story of educated experienced technicians hurting themselves. I have 9 and 1/2 fingers.
Ur right, I toasted my battery! Won't even take a charge now.
The orange wire in pin 16 is usually the power feed that's 12 v. at all times. Now we know for sure. Sorry to hear that autozone sold you another defective battery. Good thing it's under warranty.
