One Rear Power Door Lock Will Not Work.
I have a `94 s-10 Blazer 4-door Tahoe LT. The left rear power door lock quit working and I was so sure that it was the door lock solenoid that I went to the bone yard and pulled one. ( I know, I know, I did not want to pull the door panel twice.) When I put it on it still did not work so I checked the power and sure enough, no power to the solenoid. The right side works fine. I was wondering if someone else had this same problem and where you found your power break at? Thanks.
OK. Here is a long overdue update. I pulled the inner panel on the door post ( this is where the door wireing harness pluges in ) and found that I had power going to the door. So I ran an Ohmes test back thru both wires for the door lock ( the gray wire and the biege wire ) and found that I had a break in the biege wire. Now all I have to do is replace/bypass that wire and that should fix the problem. I hope this helps someone.
BlueDSM
08-11-2010 05:05 PM
ussexplorer
04-16-2010 04:49 PM
ussexplorer
04-04-2010 08:39 PM
rossg
05-27-2009 07:48 AM
