popping thirty amp fuses like candy
Old Dec 5, 2011 | 06:36 PM
gearhead23's Avatar
gearhead23 is on a distinguished road
Default popping thirty amp fuses like candy
i just recently fixed my smog pump on by '01 chevy zr2 blazer and i just got done installing it and i found out that there was a 30 amp fuse that i needed to replace because it had blown that fuse is located between the battery and the passenger side fender allong with a little ten amp fuse. but anyway i replaced it no problem and the pump truned on and about a month later the same fuse poped and i was wondering what would be causing it to pop? please write back.
Old Dec 5, 2011 | 06:42 PM
warthogdriver's Avatar
Is part of the harness grounding out somewhere? Just a thought. Might be more to it then that
cprettymerk
Oct 31, 2012 08:17 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
oktain
May 12, 2010 09:47 PM
Ryanmatt135
Apr 5, 2010 05:22 PM
Colby 04
May 6, 2009 08:04 AM
