Power Mirrors Not Working.
I just got a 1998 2 Door Chevy Blazer From my uncle, and right after I went out for the first time with it, I found that the power windows aren't working. I was wondering if anyone knew what/where I could check to fix it. Sorry if this is the wrong area, I'm new to the forum and this is my first post.
try fuses?
switch itself might be bad.
loose wire behind door panel.
i was able to pick up a new switch set for driver door from junk yard for cheap.
easy to swap out.
just a suggestion. try fuse or loose wire first.
i am thinking if both mirrors are out, maybe switch went bad.
easy to swap out.
common issue. a lot of moisture gets down in those switches on the d side door.
Pull the switches, take them apart, and clean all the contacts with rubbing alcohol and/or a pencil eraser. Re-assemble and give it a go. you can also try diagonal angles. sometime you can "force it".
RoxStar33
Nov 26, 2012 07:46 AM
Jumpman227
Sep 29, 2012 10:02 PM
kickme005
Jul 10, 2010 10:07 AM
shibbershabber
Feb 21, 2010 12:43 AM
fresno99
Jul 31, 2009 08:12 PM
