Power seat switch boxes
Old Oct 14, 2024 | 01:00 PM
JTSherer's Avatar
JTSherer is on a distinguished road
Default Power seat switch boxes
If you have power to the seat harness, your probably going to have to do what I'm doing right now.
Clean all the contacts in the whole dang box. Factory put so much grease in these, man, I have no words.
Your going to have to drill out the screw in the center of the back. No worries, it doesn't have anything behind it. Mine broke so it was easy to pull the clam open.
8 ****** clips you'll have to pick at.....to "open" the box
The seat buttons clip onto the levers, the seatback button has a stem that, well, just leave that on the cover, it'll be fine.
The lever pins fall out easily so make sure you have a good handle on the box until you orient yourself to whats what in there.....I have medium fat fingers so I use a pick for alot of things.
Hope this helps a few.....cured all the seats in op, sometimes op, every other try op symptoms....this was the cure.
Got it done and the seat works like new!
gm power seat switch box
Old Oct 14, 2024 | 01:44 PM
I'll edit this post as the info crosses my desktop. I'm on my phone now and this is where I'm at with this.....heading back out with alcohol and qtips.
Nevermind, I can't post photos yet.
I'll update this with photos Incase you lose track of where all the dip switches belong.
Dolphin *****.
This will be good info to have on the forum. Thanks for posting about it and good luck!
Old Oct 14, 2024 | 05:41 PM
JTSherer's Avatar
I'm not gonna waste anyones time
TonyZR2
Sep 26, 2014 05:26 AM
TrTl
Sep 22, 2012 09:56 AM
ludude1975
Nov 16, 2011 06:21 PM
tommyd
May 6, 2008 11:31 AM
TheDesertFox
Nov 25, 2006 10:58 AM
