Power Seat Wont Recline
Old Dec 21, 2011 | 10:08 AM
neospyder's Avatar
neospyder is on a distinguished road
Question Power Seat Wont Recline
Question for everyone - I am swapping to power seats in my 99 Blazer and after putting in the driver side I have front/back/tilt movement but the lumbar and recline functions do not work. I checked voltage coming from the switch for the recline and it is working, but I am not hearing any motor noise whatsoever when I move the switch.
So here is what I'm curios about:
1) How do I get to the recline motor? (not sure how to disassemble the seat)
2) Is the lumbar/recline problem connected?
3) Any other suggestions?
Thanks in advance!
Old Dec 21, 2011 | 10:56 AM
jimhens82's Avatar
jimhens82 is on a distinguished road
sounds like the seat recline motor is out, you have to remove the seat, then the backrest and tear the seat down.... but before u tear it down see whats accessable with it upside down on a bench
by moving the switch u should be able to tell which motor does what
Last edited by swartlkk; Dec 21, 2011 at 11:24 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 21, 2011 | 12:07 PM
Please take a look at the attached.
In the first picture:
  1. Seat Horizontal Motor
  2. Seat Adjuster Switch
  3. Seat Front Vertical Motor Connector
  4. Seat Front Vertical Motor
  5. Connector C317 (LH)
  6. Seat Rear Vertical Motor Connector
  7. Seat Rear Vertical Motor
  8. Seat Horizontal Motor Connector
In the second picture:
  1. Seat Back Cushion, Top
  2. Seat Recliner Motor
  3. Seat Lumbar Motor
  4. Lumbar Support Grid
To get at the recline & lumbar motors, you'll need to pull the cover off of the back of the seat or at least enough to get your hand in there and get the connectors off the motors to test for power/ground to each motor that is not working.
Attached Thumbnails Power Seat Wont Recline-8way_pwr_seat_motors_1of2.gif   Power Seat Wont Recline-8way_pwr_seat_motors_2of2.gif
rwsturbo
Jul 20, 2015 01:20 PM
BlazerBane86
Jun 29, 2015 11:59 AM
1980gold
Dec 11, 2012 11:28 PM
ExplicitYourSelf
Jun 16, 2009 06:35 PM
2002XTREME
Mar 21, 2008 04:18 AM
