Question on Actuator
Old Sep 22, 2012 | 04:52 PM
HellBilly93's Avatar
HellBilly93 is on a distinguished road
Default Question on Actuator
Ok I searched and didn't find anyone else having this issue.....first off its a 1993 full size blazer. I changed this over to a standard from an automatic I used the motor and tranny from a 1991 full size truck. I changed computer and wiring harness also.....now the last issue I'm having is the actuator switch isn't working. I'm sure from changing out the computer and harness. Issue is I can't open it so I can rewire it... Jumping 12v to the switch isn't helping so I'm sure it's the wire going to the actuator.....long story short anyone have the wiring diagram or can anyone tell me which wire I'm lookin for here. Thanx n advance. Great forum.
Old Sep 23, 2012 | 06:19 PM
Come on guys I see some great mechanics n here someone has to have an idea.
Old Sep 23, 2012 | 06:54 PM
xgiovannix12's Avatar
You can hook up a solenoid if the actuator is operated VIA vacuum. There is a DIY in my Sig.
Edit: Dont full sizes have this system ? http://i.tfcdn.com/img2/nXzhh0oAY2Le...HAA**/fyVMtP8A
If you feed 12 volts to it. IT needs to extend its self... IF not the actuator needs to be replaced.
blaze77
Nov 29, 2011 03:05 PM
big bad vvolf
Jul 22, 2011 06:14 AM
HiRidinChevy93
Apr 27, 2011 07:29 AM
gmoney30
Feb 6, 2010 07:58 PM
markrd
May 8, 2009 01:39 PM
