Scanner won't link to computer
Old Nov 20, 2021 | 04:10 PM
  #21
Does this help? Cell phone view...
Hope i dont have to draw a picture of a finger....
Old Nov 21, 2021 | 06:28 AM
  #22
Phil Manwarren's Avatar
Phil Manwarren is on a distinguished road
ok how do I check each one and is there something I can make it looks like one connection and to a bunch of other connections is that rite ? what I mean is can I make a wire that does that or is that hard to do ?
Old Nov 21, 2021 | 09:59 AM
  #23
GeorgeLG's Avatar
All of the class 2 serial data lines from all of the modules and the DLC are tied together in a star configuration at splice pack 201 under the dash near the IP fuse panel. I believe that your truck will have a comb insert that ties them all together. You remove the comb and add each module back until the data buss fails. Then you figure out if it’s the power or ground to that module, it’s wiring or connectors or a corrupted data wire that is shorted to power or ground - or the module itself. It sounds like you already know that the tccm is hosed so you can start there if the more complete process is an issue. Here are pictures of your data line schematic (if I remember correctly and this is a 2000), what the splice pack and comb probably look like as well as a professional jumper wire set. You can either buy one of those or fashion your own. If you have an o scope then diagnostics is even easier. I included a screen capture of clean serial buss data. If you don’t have a scope then a scanner that is still displaying live data is not foolproof but a reasonable indicator of a clean data buss. In this case you would have to star the v/e/pcm and dlc together first then start adding or subtracting modules.
George
Old Nov 21, 2021 | 10:34 AM
  #24
GeorgeLG's Avatar
Here is the test lead kit for the class 2 data splice pack I showed in case diy jumpers are not your thing:
https://www.aeswave.com/uIsolate-Net...tor-p9669.html
George
Old Dec 30, 2021 | 11:03 AM
  #25
Krupek's Avatar
Krupek is on a distinguished road
Default Vcm connector diagram chevrolet blazer 1999
[QUOTE=GeorgeLG;738515]Here is the test lead kit for the class 2 data splice pack I showed in case diy jumpers are not your thing:
George[/QUOTE
Hello,I need a wiring diagram for VCM plugs for Chevrolet Blazer 1999 VIN 1GNDT13W1XK124511
thank you very much for all the help
Old Dec 30, 2021 | 11:16 AM
  #26
GeorgeLG's Avatar
[QUOTE=Krupek;739248]
George[/QUOTE
When you have an unrelated question from the subject of the thread you need to start your own thread or else the questions and answers get mixed up and turn the thread into a mess. A classic thread hijack. Post a new thread for your problem and I’ll post the wiring diagrams that you need and be glad to answer any questions that you have.
George
hoebob69
Feb 25, 2017 05:35 PM
Phil T. Chambliss
Oct 1, 2016 11:24 AM
Blazer_LT
Nov 6, 2011 06:03 PM
azembdriver
Jul 28, 2009 07:19 AM
blazingsadle
May 8, 2006 08:38 PM
