security light issue
Old Sep 16, 2012 | 04:29 PM
warthogdriver's Avatar
I understand your frustration....this issue was the worse i have ever dealt with...felt helpless as i poked around in hopes i would find the problem. If the battery is disconnected you should be fine disconnecting the bcm. I would check the pcm...how about the ground at the fire wall on pass side...is it in place. Your guy might be better then my dealership exp...they were useless....they wanted to keep tearing the truck apart....when i realized they were hunting like i was i halued it back home.
Old Sep 20, 2012 | 12:58 PM
lonewolfe23's Avatar
lonewolfe23 is an unknown quantity at this point
after reading everything and searching thru wires and trying to figure out a solution i think my only choice left is to go to the stealership and cut off a leg or an arm
Old Sep 20, 2012 | 04:28 PM
ok i walked down the street and talked to one of the mechanics at the chevy dealership and he advised me to put some di electric grease on some of the components in the fuse block to see if maybe there isnt a strong enough connection and told me to check the lines for a break in a wire before i bring it in so as ive been advised many times on here as well as others im going to check it out again...time for round 6..hopefully this will lead in a better direction and maybe ill find something ive overlooked
Old Sep 20, 2012 | 05:58 PM
question can a fuse box be bad and still get power i put one test light on it with a ground wire and they all light up now i have another one that has a positive and a ground wire and only a few light up mostly the smaller one
Old Sep 30, 2012 | 01:34 PM
ok after doing some research and speaking to some people i found a guy locally who is very good with electrical issues not to mention fair priced and he told me that all my symptoms add up to a data line short he just had a blazer in there that had the exact same thing going on with it in his shop so id like to thank everyone who took the time to read my post and warthog for taking the time to answer me you were right on the money with the wiring
Old Sep 30, 2012 | 07:26 PM
well i am glad you finally found away to deal with this. i would be interested to find where the failure was.
like i said...i hate electrical issues more then anything. that is why with the exception of my wives jeep all three of "my" cars are from the mid 90's. just enough electrical for me thank you very much.
Old Oct 12, 2012 | 06:41 PM
well i got the blazer back yesterday and the problem was the ...pcm malfunctioned so 350 dollars later she is up and going purring like a kitten
wlorton
13
Sep 11, 2013 05:48 PM
Tony H
Sep 14, 2012 12:22 AM
vlb6472
Jan 19, 2012 06:18 PM
Chris99
Sep 28, 2011 03:52 PM
red/white04
Jan 28, 2009 08:03 AM
