Turn key lose all power
Old Jul 14, 2012 | 12:54 PM
Jcog7293's Avatar
Jcog7293 is on a distinguished road
Default Turn key lose all power
Hi I'm having sort of problem ... My 2001 blazer will have power so lights will come on inside truck and whatnot but when I try to start it it just clicks and I lose all power ... Then I gotta mess with the battery terminals to get power again ... Then try to start and it loses power again ... I know it's not the battery or starter because I just bought a new optima red top and a new starter ... And help/suggestions/info are greatly appreciated thanks
Old Jul 14, 2012 | 01:18 PM
Have you tested for power at the ends of your main battery cables to make sure that they are good after they try to pass high amps? Sometimes the fusible links can pass through low amperage power, but open up when high amps are requested.
Old Jul 14, 2012 | 02:05 PM
Jcog7293's Avatar
The cables leading off the battery? No I have tested all my fuses and fuse box to make sure there wasn't a short ... What cables should I test?
Old Jul 16, 2012 | 09:30 PM
Chumba87's Avatar
Chumba87 is on a distinguished road
Sounds like a bad ground or maybe corroded cable inside somewhere... I would check all grounds first
Old Jan 30, 2020 | 12:31 AM
Trexaw's Avatar
Trexaw is on a distinguished road
Default Lost power
Same problem with my 2001 blazer have lights but not sure if alternator or starter battery didn't hold high voltage
Old Jan 31, 2020 | 09:53 AM
This thread is 8 years old. Might want to start your own for a better response...
greasyhands
Dec 18, 2012 06:42 PM
dbennett0307
Feb 26, 2010 01:34 AM
bear
Jan 5, 2010 02:51 PM
tidoux01
Mar 5, 2007 07:07 PM
