turn signal issue
Old May 25, 2014 | 02:37 PM
SimonV's Avatar
SimonV is on a distinguished road
Default turn signal issue
I have an issue with the turn signals. It's a '89 S10 blazer.
The left turn signal works how it should. Turn signal to the right isn't flashing but everything seems to light up on the outside.
Then when I turn on my lights while I am not using the turn signal the green arrow in the dashboard also lights up. When I use the right turn signal when the lights are on, the turn signals aren't on, no light in there ...
Fuses seem to be ok
Old May 25, 2014 | 08:39 PM
richphotos's Avatar
I feel like I have answered this already here or somewhere else.
I would start by replacing all exterior bulbs (tail lights, bumper blinkers and the marker lights on either side of the grill.
Could be one of the filaments in the dual filament bulb broke and is making contact with the other causing a short.
If that does not fix it, there are 2 grounds located on the core support, one is behind the battery, and the other is on the drivers side behind the horn. Take those off and clean them.
There is a ground in the back as well, but I am not sure on the location.
If that does not work
Try a new dimmer/headlight switch.
Old May 26, 2014 | 12:50 AM
odat's Avatar
[QUOTE=richphotos;627925]I feel like I have answered this already here or somewhere else.
yup you have
from the last few posts this has been brought up this time you forgot to add check sockets for corrosion, clean insides well and lube with diaeletric grease
Old May 26, 2014 | 11:28 AM
richphotos's Avatar
[QUOTE=odat;627934]
yup you have
LOL I knew it, had a strong deja vu with it.
Yes, clean and check sockets too.
Old May 27, 2014 | 12:36 PM
SimonV's Avatar
Found it, a broken wire behind the front bumper.
Old May 27, 2014 | 01:16 PM
richphotos's Avatar
Glad you figured it out!
Old May 29, 2014 | 03:06 PM
SimonV's Avatar
Now I can start to figure out why it suddenly decided to rev up to 2500rpm while iddling ��
Old Aug 17, 2014 | 02:12 PM
SimonV's Avatar
my turn signal still doesn't work as it should. It works without my lights on, hazard warning lights also ... only with my lights on they hang ?
I now noticed that when tick on the relay that it does blink, once. Also when i have a lot of patience and switch a bit from left to right it starts working.
Time to get a new relay ?
SubbinBlazer
May 24, 2013 12:56 PM
ta3ff
Oct 14, 2009 05:07 PM
greengoose89
Feb 11, 2009 09:07 PM
KSEScream420
Dec 31, 2008 09:24 AM
shaka1111
Feb 13, 2006 02:23 PM
