Turn Signal Lights
Old May 27, 2011 | 10:40 PM
newwithanoldie's Avatar
newwithanoldie is on a distinguished road
Unhappy Turn Signal Lights
I recently bought a 1984 Chevy Blazer S-10 that has been sitting around for nearly 10 years and have been working to restore it to its former glory, everything seems to be going well, but I can't seem to figure out the turn signals.
To put it simply, the left turn signal doesn't work properly, the right one and the hazards work perfectly. When I turn on the left turn signal, both the front and rear lights turn on solid. I've looked around and can't find a solution... Help?
Old May 28, 2011 | 09:25 AM
jackdough's Avatar
jackdough is an unknown quantity at this point
sounds like a bad relay or switch at the colum to me. i know the older ones like your tend to have wiring issues around the steering colum. might be a good idea to take a good look around. could be just a pinched wire or something. good luck
Old May 28, 2011 | 12:20 PM
wrenchturner3529's Avatar
wrenchturner3529 is on a distinguished road
Could be a bad ground wire or a wrong buld used. I would also clean the contact points in the socket to ensure no corrosion is there.
Old May 28, 2011 | 02:19 PM
rriddle3's Avatar
*Moved to 'Lighting & Electrical'. Please read the section descriptions to determine the correct area for a thread prior to posting.*
Old May 31, 2011 | 04:27 PM
Where would I be looking for the pinched wire? I don't see an easy way to get a good look at the wiring on the steering colum...
SubbinBlazer
May 24, 2013 12:56 PM
ta3ff
Oct 14, 2009 05:07 PM
laserblazer
Mar 19, 2007 06:37 AM
rryker
Apr 25, 2006 04:14 PM
shaka1111
Feb 13, 2006 02:23 PM
