turning off the accessories outlet
Old Sep 21, 2013 | 03:49 PM
TAZ454's Avatar
TAZ454 is an unknown quantity at this point
Default turning off the accessories outlet
Is there a way to turn off the accessories outlets on a 98 Blazer, when you turn off the ignition ? I hooked up a xm radio it gets power from the acc outlet if I forget to unplug it will drain my battery.
Old Sep 21, 2013 | 10:41 PM
Thogert's Avatar
You could wire a switch in-line with the outlet, but you'd need to be careful with how many amps you are running through it.
Old Sep 22, 2013 | 08:39 AM
rexazz2's Avatar
you could loop the fuse with a relay and fuse
Old Sep 23, 2013 | 12:28 AM
Thogert's Avatar
Personally I'd just wire in a new acc powered outlet. Or, even, just cut the wires to one of the stock outlets, and grab power from an acc powered circuit and wire it up. Of course it is always a good idea to use a relay and fuse just in case, but I know the risks.
Old Oct 23, 2013 | 07:59 PM
necropenetrator's Avatar
necropenetrator is an unknown quantity at this point
alot of those multi port charging port accessories u can buy have automatic protection where it stops power to devices when the battery dips a little below 12v i have one spliced into the cigarette lighter port
Old Oct 26, 2013 | 03:18 AM
Thogert's Avatar
Discharging a lead-acid battery below 12V is actually not healthy for the battery. 12.3 or around there would be the lowest I'd be comfortable dropping mine.
Staticxtreme5
Mar 31, 2011 07:43 PM
jeffintoronto
Dec 16, 2009 11:54 AM
<3blazer
Headers, Intake, & Exhaust
Jul 13, 2009 11:09 PM
ncmudblazer
Jun 5, 2008 03:50 PM
burak sozer
Jun 4, 2008 02:05 AM
