wanted to upgrade stock light bulbs to leds.
Old Oct 16, 2014 | 09:30 PM
Bighddaddy's Avatar
Bighddaddy is on a distinguished road
Post wanted to upgrade stock light bulbs to leds.
I changed the rear brake light bulbs to leds and the blinkers were fast. so then I changed the front turn signal bulbs and the blinking went back to normal. I turned on my headlamps manually and the signals worked fine with the stock relay flasher. my only problem is at night when the DRL's turn my headlamps on the signal lights do not work, and the signal light indicators in the cluster glows dim. would appreciate any help or info on to fixing this. all the led's i purchased from Superbrightleds.com on my 1998 blazer 4x4..
Old Dec 8, 2014 | 03:11 PM
I'm in the same conundrum myself with my 04 right now...
Old Dec 10, 2014 | 12:36 AM
LeWhite's Avatar
Can you put the signal leds in backwards and see if the anomialy is reversed?
Old Dec 10, 2014 | 07:06 AM
I did and it didn't do anything but just refuse to work... at all... running lights or turn signals
96jimmyslt4x4
Sep 21, 2011 09:14 AM
ComputerNerdBD
Aug 28, 2011 12:50 PM
LuvMyTJ
Apr 22, 2010 09:59 PM
butters
Oct 14, 2009 04:26 PM
Blazers.B.Kewl
Sep 8, 2009 04:22 PM
