window wipers
I just searched for "wipers keep going" & came up with...
https://blazerforum.com/forum/2nd-ge...ghlight=wipers
https://blazerforum.com/forum/lighti...ghlight=wipers
https://blazerforum.com/forum/1st-ge...ghlight=wipers
You probably can find the cause to your issue/s in at least one of those threads.
Actually there was a recall about this. GM concluded it to cracked solder joints on the board for the wipers.
Link I know it says it'll make your wipers go intermittently or not at all, but I would assume it could also cause your wipers to go and go and go... I'm actually currently having the same problem.
Really? wow.... I know mine (when they feel like it) won't always stop at bottom (when I shut them off) when I have them set to run at slow or fast. But set to intermittent wipers & they cycle & stop where they should stop. So the easy fix I found was to set them to intemittent & shut them off when they're at the bottom of the cycle.
yep i had the same issue with my and it was the the wiper pulse module, 1992-1997 Chevrolet Blazer Wiper Pulse Module – Replacement C361701 - Wiper Pulse Module - Replacement
e602
91
03-08-2015 04:53 PM
Fosse
08-22-2011 06:43 PM
hillbillyinOhio
07-12-2006 04:18 AM
