Wire Harness Cut (for stereo head unit)
Old Jan 11, 2013 | 05:01 PM
DerickAvard's Avatar
DerickAvard is on a distinguished road
Exclamation Wire Harness Cut (for stereo head unit)
okay well, long story short, my internal wire harness was cut, now this isnt a problem because i got a replacement from a junkyard (same car, same harness) so all i have to do is connect the wires. The problem is that a few wires share the same color, how am i to know which is which?
(P.S. its a [s10] 2000 Blazer)
Old Jan 11, 2013 | 05:19 PM
richphotos's Avatar
If there is any that share the same color, check the wires closely, for a white line, or if ots sold ect, or even words for what its for.
Old Jan 11, 2013 | 08:44 PM
Twip's Avatar
could have a white line like stated above or, it could have a black stripe on it. not long ways like the white stripe would be. it would go across the wire. if you are holding the wire in your hand straight up and down then the stripe could go from left to right. just look carefully.
Old Jan 11, 2013 | 08:47 PM
rexazz2's Avatar
not sure why people cut the harness ,the vehicle specific adapter kits are cheap and easy
BTW you may have multiple solid black wires they all should be speaker grounds and they are probably all the same gauge wire
Old Jan 12, 2013 | 11:36 AM
I checked and there are no indication to which wire is which, they were cut pretty short so i feel like if anything the indicators were cut off... so where do I go from here?
Old Jan 12, 2013 | 11:49 AM
Sorry for the double post, but if you look at this, it shows dark green as two different things, as well as gray, If I took a shot, and accidentally mixed those two up, will it blow anything? Or would it be worth it to just guess and check?
2000 Chevrolet S10 Blazer Stereo Wiring Information
Radio Constant 12v+ Wire: Orange
Radio Switched 12v+ Wire: Dark Green
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Stereo Dimmer Wire: Violet/White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Old Jan 12, 2013 | 01:55 PM
richphotos's Avatar
Like already has been said, there will be distinguishing marks on the wires to separate them form the other. white line or something,
The gauge of the speaker wire from the other wires is different as well.
Old Jan 12, 2013 | 04:46 PM
rexazz2's Avatar
A test light or voltmeter will help you sort out the greens ,switched will become live when you turn on the key jusy make sure none of the wires are touching anything
The grey will be the same illumination should become live with headlights
SubbinBlazer
Apr 5, 2013 09:17 PM
flaboy420
Nov 27, 2011 09:35 PM
djback
Sep 10, 2011 01:17 AM
mr.vls
Mar 13, 2009 02:32 PM
