Notices
85 Blazer K5 Power steering fluid leaks out of the top
Old Aug 26, 2012 | 09:03 AM
Agentsnake's Avatar
Agentsnake is on a distinguished road
Default 85 Blazer K5 Power steering fluid leaks out of the top
Hello Folks,
I know this is not the right section to open this thread but I am a new memeber and can't post it anywhere else.
Short description of my problem :
Power steering fluid leaks out of the top of reservoir
- I did check the fluid level and did make sure it is way on the
lower side
- I did replace the cap just in case
- I did check the low pressure ans high pressure line they are fine
- I do have little wine noise but not so bad
- When I drive steering goes easy if I stop it goes easy in the first moment than steering becomes weak if I rise the rpm in neutral a little steering works better .....
I feel sure the pump is just old and need to be replaced what you guys think ?
thanks for any tip
regards
Gunter
jake kick
Apr 27, 2013 01:25 PM
rocknroadie
Jan 22, 2013 06:05 PM
tomf216
Jan 28, 2010 07:37 PM
90blazinchevy
Oct 5, 2007 01:52 PM
gmaltese
Sep 15, 2006 01:18 AM
