99 Pontiac Grand Prix
Old Apr 21, 2012 | 08:20 AM
tripovermyego's Avatar
tripovermyego is on a distinguished road
Originally Posted by RetroBlazer
One of my passions is the W-Body.
As for the battery, 99 times out of 100 the culprit is the nut that holds the positive battery cable to the stud on the passenger fenderwell. It's usually loose or corroded. And it also could be the starter, I've had that style do the same thing to me before.
I'd also be willing to bet the cooling system has an air lock in it from the leak, the leak could be from the thermostat housing or the throttle body coolant line or gasket.
Have you ever changed the rear struts on one of these? If so, is it as bad as it looks? From the looks of it, Ive either got to take out the backseats or climb in the trunk and take out all the bolts. I wonder what way would be easier or if youve done it and know of a better way.
Old Apr 21, 2012 | 11:39 AM
ohsofly's Avatar
U cam get the strut nuts from the trunk. Its not a bad job at all. You will need spring compressors though.
The intake is also cake on the 3.1
And IMO the 3.1 is an excellent engine! Amd they sound great too.
Old Apr 21, 2012 | 08:09 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
yeah the intake gaskets are pretty simple to change, only thing to watch for is the push rods are 2 different lengths, and the older engines have adjustable rocker arms so be sure to count the turns, as far as cost goes depends on how much you pay for a gasket set.
Last edited by Jase1979; Apr 21, 2012 at 08:10 PM. Reason: and yes they are very good engines imo
Little Roober
Mar 7, 2013 09:49 PM
ussexplorer
Apr 6, 2010 11:27 PM
Dakota_Don
Apr 7, 2009 02:37 PM
Jharper
Street N Strip
18
Dec 25, 2008 04:37 PM
Zygoat
Engine & Internal
17
Jul 12, 2007 06:16 PM
