Best way to syphon fuel from car?
Old Apr 21, 2011 | 10:42 PM
oktain's Avatar
Originally Posted by streblo
or you can use your pipes grip each side and rip the tank apart..
could probably drill the bottom on low speed on the drill, low chances of sparking then
Electric motor in the drill loves to give off little sparks... I personally think his best bet is to start by dropping the tank. When it comes to something that's as potentially dangerous as this situation shortcuts are NOT an option. Drop the tank and go from there, either cut the filler hose off with a pipe cutter (no filings) and syphon from there, or try putting power to the fuel pump. Keep a fire exstinguisher near by as well, as was stated make sure it's ABC.
Old Apr 21, 2011 | 11:00 PM
streblo's Avatar
ok go old school and use a hand drill :P haha, I think best/easiest way to recover the gas is def running the fuel line into a countainer and putting power to it.....dropping the tank is probably more time and effort than the amount of gas your going to recover.....you could always dump some fuel stabilizer in it, then put a pan of salt water to the bottom and wait for it to corrode until the gas leaks out, then it might be worth 2 bucks a litre
Old May 19, 2011 | 09:07 PM
hellrasin''s Avatar
hellrasin' is on a distinguished road
i like the way you think ;]
Old May 19, 2011 | 09:42 PM
chris015's Avatar
Find the fuel relay and jump the 2 connections with a paper clip? Thats what ive done to 3 cars. Pumps purrs like a kitty and gives me gas. haha
Old May 19, 2011 | 11:55 PM
ohsofly's Avatar
That anti syphon thing only works for hoses the size of the hole for filling. Try using some 3/8 tubing. Mines about 15 foot long, I prod it around till it gets through the blockages, and then jam most of it in the tank so only a littles sticking out. Then I stick a thumb on the end, and pull 10ft back out - hold it down below the tank - and take thumb off. Works like a charm but its gonna take a while, I usualy just fill the mower tank from my blazer since its not going anywhere anytime soon. Ive had sucess getting larger hose in there, but its kinda hard so I use the small hose.
bigmatt1
Lifting Tech
16
Dec 31, 2009 05:07 AM
99 Blazer 4x4
Suspension Tech
Sep 25, 2007 11:45 AM
JLaw
Suspension Tech
Mar 2, 2007 07:21 AM
ridin_low07
Jun 26, 2006 03:55 AM
ggwash21
Engine & Internal
Jun 17, 2006 02:08 AM
