Notices
Fm transmitter
Old May 11, 2018 | 08:59 AM
JinjerSO's Avatar
JinjerSO is on a distinguished road
Default Fm transmitter
I'd like to build a stereo fm transmitter to send my mixes out to the car and listen... What's the best circuit for the best hi fi sound ? Anything out there that is cheap, that can compete with the quality the local radio station is transmitting, but just on a smaller scale... probably around half a watt or so ?
Any tips ? thanks.......
Old May 11, 2018 | 01:34 PM
LesMyer's Avatar
Something like this?
Amazon Amazon
I had a mp3 player/fm transmitter 15 years ago. It's pretty old technology. Modern car stereos have Mp3 and Bluetooth built in.
Old May 11, 2018 | 02:12 PM
Rusty Nuts's Avatar
I remember when high definition meant you had tin foil on your antenna. Not useful, but funny now.
Old May 14, 2018 | 03:28 AM
JinjerSO's Avatar
Guys, someone edited my previous comment, I did not leave any references there! Probably you got a hacker-spammer. Or the moderator has edited ... In general, if I do not bear any responsibility!
Lesmyer, yes! But but I'm considering a model GoGroove FM transmitter
So, Has your transmitter been running for 15 years? Wow
Rusty Nuts, аortunately, I did not find those times because I did not need to have any transmitters or antennas )
Old May 14, 2018 | 05:43 AM
Your post is EXACTLY as it was submitted by you on the 11th.
On the topic at hand, low power FM Transmitters are very low power transmitters (typically less than 1 µW) that are good for a hundred feet or so in unobstructed flat land. Looks like you want to go considerably farther than that as you stated 0.5W...
The FCC (in the US) and IC (in Canada) both have published limits for personal unlicensed broadcasting on the FM bands. Best to do some research before you get yourself in trouble.
Old May 14, 2018 | 05:59 AM
JinjerSO's Avatar
I am sorry, I can wrong, but as you see this two word are marked as links on Amazon...
Do not they show up like that? I just warn you that you did not have any questions. I'm sure that the modification works at the highest level.
And now about the theme of a topic.
Do you think my transmitter is too powerful? That is because of this there may be a problem? I'm a little dumbfounded
Ou... Something wrong and I cant receive picture.....Anyway, in my first comment words "stereo" and "circuit" are marked like links to Amazon.
Old May 14, 2018 | 10:25 AM
LesMyer's Avatar
Actually I used mine very little and for a very short time. I soon bought a cheapie car stereo that had USB input and would play MP3s. I now have a couple of the do everything car stereos and have never looked back. AM/FM/CD/Bluetooth/USB/Flac/Wave/MP3/Phone w/Mike/etc. 30GB flash drive in the glovebox off the rear USB input with enough MP3s for a VERY long road trip!! If I run out I can Bluetooth music off the 20GB micro SD card in my Android phone. Seldom play CDs in the car anymore, but I still like having the option.
The links get inserted automatically by the forum. Apparently some advertising $$$ to help maintain the forum.
Old May 14, 2018 | 07:59 PM
Yeah, this. I don't see them for a variety of reasons so I forget that they still appear for others.
You stated a half watt transmitter which puts you well over the regulated limit for unlicensed FM transmission. Most of those that were listed on the "comparison" site you posted should be below the regulated threshold and as a result will be no where near a half watt.
Old May 15, 2018 | 01:42 AM
JinjerSO's Avatar
Well....I heard you guys. Thank you
Old Jul 22, 2018 | 12:48 PM
VI-Joe's Avatar
VI-Joe is on a distinguished road
If you’re still looking for a solution, you may want to strongly consider replacing the whole radio. You can get a new one that does Bluetooth, USB, SD, and AUX for under $100 from a good brand (with install parts). You’ll have far more wattage available which actually cuts down on audio distortion. A website like Crutchfield will make sure you get the proper dash adapter, wiring harness, and antenna adapter. If you’re going through the trouble, you may as well just upgrade. Just my two cents. Good luck!
swartlkk
Mar 22, 2011 07:54 PM
blazerJim1701
Jan 29, 2011 01:28 PM
EzTec
Apr 28, 2010 09:41 AM
LuvMyTJ
Feb 24, 2010 02:19 PM
