Notices
heated mirrors
Old Mar 9, 2011 | 11:46 PM
  #21
streblo's Avatar
replaced passengers already, drivers the liquid all screwed and the mirror is weird but still works so ill leave it for now.
Being in Winnipeg i knew they were heated the day i bought it, haha
Old Mar 10, 2011 | 04:26 PM
  #22
GetNice24's Avatar
GetNice24 is on a distinguished road
thanks old skool, Im gonna get at it this weekend and ill let you know how it turns out. as for the doorskin, does it clip in and i jus pull it off or are there screws hidden somewhere ? thanks again
Old Mar 10, 2011 | 11:04 PM
  #23
streblo's Avatar
bolt underneath the arm rest, need an extension on the socket, its like a 8mm or 10mm or something, you get at it from underneath, and screw behind the inside door handle, then you pop the plastic push pops from the bottom of the door up, then you lift the door straight up (it hooks on the window sill)
Old Mar 11, 2011 | 01:36 AM
  #24
old skool luvr's Avatar
you know.........i thought i had mentioned how to do that on the last page, but i'm to tired to go check (hey! i just did a 17 1/2 hour day setting up for the show)
there are actually 2 bolts under the arm rest, and they require a 8mm socket to remove them.
the angle is kinda odd & screwy, so take a good look @ them when you're removing them.
be careful on the belt molding, it can really get buggered on the door when you remove it. lift the back off first with a sharp lift stright up like Jon said.
1997GreenBlazer
May 20, 2021 09:00 AM
chris015
Jul 8, 2012 01:19 AM
old skool luvr
Nov 15, 2009 10:32 AM
Sisk
May 29, 2009 01:13 PM
mistasmiff
Aug 17, 2006 01:36 PM
